Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
RedBatman89
Mar 09, 2019Guide
Hi so I had upgraded my Firmware a few days ago manually and things seem to be pretty good so far. However I do beleive that daisy chain topology is still a little bugged. When I decided to disable it, upon reboot one of the sattelites decided to connect to other one isntead of connecting to the router. So I had decided to power cycle both the modem and router, while this time both sattlites connected to the router but it took longer. I think its because the firmware still beleives topology is enabled when its still diabled.
Mar 09, 2019Guru - Experienced User
If you have the 20 series Orbi system and upgraded to v28, please post all of this here:
This thread is for the 50 series Orbi systems running v32 FW.
Thank you.
