Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
HannoosH
Mar 10, 2019Aspirant
Before the upgrade - everything was ok in ORBI RBK53 ... Download speed was about 57 Mbps and upload speed about 17 Mbps .
After the upgrade (which went well with no issues) the both upload and download speeds are not exceeding the 9.5 Mbps . I tried alot of configuration and reset factory settings but with no use . I opened a ticket with the support but still the problem persist and still have the issue .
Please support to resolve the issue or at least provide the steps to return back to the old firmware .
Just to highlight that I am using ORBI from just 3-4 days and this experices is not good for new users
- HannoosHMar 11, 2019Aspirant
Just to highlight the older Firmware that was working with no issues with me before the upgrade to 2.3.0.2 is V2.2.1.210
- gr8shoMar 11, 2019VirtuosoHello. You’re likely going to get a series of questions such as how is your Orbi’s host router port configured (DMZ is the optimum answer).
But as for downgrading, would need to be done my going to the support website and downloading the two corresponding files for the base and satellites, and using the web GUI to manually apply them along with a corresponding factory reset.
If you can wait on some of the other help, might be a better choice from a total time perspective.
BTW, what ISP service you have there?- orbilovMar 17, 2019Apprentice
Wireless is fine, firmware gets fully downloaded prior to update commencing. The only thing I found doing it over wireless ... Since one *has to* update RBR50 and should update their RBS as well to both 212 and then 2.3 you have more passes/opportunity seeing a harmless user interface hiccup.
That is sometimes the router settings page came back with success message and where I left off on the firmware management page and sometimes I had to sign back in. Then a couple of times I had to turn WIFI off on my computer and then turn it back on and let computer and router handshake again over WIFI.
** Not a problem at all and very common with any kind of work like this with any systems, some of this opportunity seeing harmless user interface hiccups would likely still be seen over a wired update.
Just a reminder be sure to download both the RBR and RBS versions of 212 and 2.3 and put RBR and RBS firmware in separate folders so you can keep them straight.
You must do Satelites firmware updates first, then the router firmware updates (Do all the 212s). Then again with 2.3, Sats 1st then router.
Lastly, note that the User interface for the updates might be confusing:
The page for manual firmware update is divided into two parts top (Router) and bottom (Satelite with checkboxes for which one if you have more than one). Yet you have to do Satellites 1st**
Also note that:
-Router section has BROWSE and UPLOAD buttons
-Satellite section has only an UPDATE button
Would make more sense if the buttons had the same names and both had BROWSE.
Good Luck.
- FURRYe38Mar 11, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Speed testing with wired or wireless connections?
Not everyone is having a bad experience with new FW.
- orbilovMar 11, 2019ApprenticeISP speed and Wifi Speed are not the same Thing. Has Furrye38 mentioned repeated wired tessts would confirm what internet speed is available. Cable modem provided internet can be highly variable for the same household by time of day and what neighbors are doing etc. Fiber like Fios is
Much more consistent and sycronous (same)(download/upload speed from isp is indicator of services that will be much less variable generally).
Orbi Rbk53 system should be providing a mimimim of over 100Mbs and in most set ups 200 to 800Mbs. Distance, walls building material, floors not with standing. When i first put out my RBK53 system i tried different placements and learned that i could arrange some of them in different locations then prior equipment , but some of my home required same as before closer placement and less walls. That is 2 walls and around 30 feet were fine, 3 walls 40 feet were not. 3 Walls provided only around 60Mbs at best.- Ragar99Mar 11, 2019Luminary
So far no major issues, I am using in AP mode.
After the upgrade, the Guest SSID was being broadcast even though it was disabled, odd but easy enought to fix. All my devices (40+) ignored the satellites and connected to the router. Once I unchecked daisy chain, devices started connecting to satellites again.
