Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Mar 08, 2019Guru - Experienced User
Did you factory reset the Orbi system and setup from scratch after loading v32? Try this next time when you upgrade. This clears out possible problems after upgrading FW. Others are reporting good operation after ugprading to v32 and doing a factory reset and setup from scratch.
mastervisa30 wrote:
Firmware Version 2.3.0.32 didnt work for me,i have droops out all the time on my 2 satellites,
poor signal and not connected all the time,my kids and wife are going mad on me.have tried reset and asked people on this forum for help but still have the same problem.
But i was going back to firmware version 2.2.1.210 and now its working again.
Iv been using orbi a wile now and the firmwares is a nightmare sometimes.
I called my store i can send it back if i want?but i dont know?
Maybe i should go for aimesh asus?ore wait for the new wifi 6 ax orbi/asus
this is startimg to be a nightmare,have been working long time now and suddenly droops out on the new firmare.
I like to test but not my wife and kids:)
mastervisa30
Mar 12, 2019Luminary
sorry late answer,i always do factory reset,and new setup everytime i install new firmware its standard for me
:)im still on firmware version 2.2.1.210 no dropps out on my satellites,working great so far now :)
