Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
pablohoney
Mar 13, 2019Luminary
So the latest update is a manual update. Why do we have to do a manual update to get the latest update??? This is 2019 and Orbi is a premium router we should not need to do this. When I check for updates it says "No new firmware update is available".
gr8sho
Mar 13, 2019Virtuoso
The technical reason for two step manual process was need to allow increase of firmware file size.
As for when the automated process will happen, NG would have to say.
I did the update manually. Supposedly once this step is performed end user can take control of when to apply updates which is my preference. I also have a preference of doing full factory reset when updates are applied, mostly as a precaution to avoid issues based on personal experience with updating router firmware.
Cheers
Cheers
