Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
Damit1
Mar 15, 2019Apprentice
Done some project this weekend, trying to re install this business with latest FW.
After factory default and everyrhing, it is a while I get 60-70/110 upload.
Wifi
Download speeds are about 500Mb, lets say is normal. Wifi
I used to get 120M upload, which hard wired I do get
Disabled Daisy Chin because it says it is aimed to more than 1 sat. I have 1 only
Channels are as used to be (loaded a backup config file)
Btw, from a tiny test I have done my HARD WIRE issue downalod seem to be solved, but i want to take a while before decalring anything.
Anymore offers?
Wifi
Anymore offers?
Zephyr3200
Mar 16, 2019Aspirant
Hi guys!
Is it safe enough to manually update the firmware even if the auto update has not started yet?
Thanks
Thanks
- FURRYe38Mar 16, 2019Guru - Experienced User
Yes,
Update the RBS's first, then the RBR. You'll need the v212 applied first to the RBR, then apply v32. Factory reset after v32 has been applied and setup from scratch.
Zephyr3200 wrote:
Hi guys!
Thanks - Zephyr3200Mar 16, 2019AspirantOk thanks .
Can i use a computer hard wired to the satellite to update or do i have to hard wire my computer directly to my router? - Chuck_MMar 16, 2019Mentor
It is preferred to be hard wired to the device you are updating just for sureity.
Can you update the satellite via hardwire before plugging into the router?
- orbilovMar 16, 2019ApprenticeWireless works as firmware is fully downloaded to device before upgrade commences. Naturally wired is more bullet proof if for no other reason you dont need to re hand shake over wifi.
- Zephyr3200Mar 17, 2019AspirantYes i will update with the satellite hardwired to my computer. But it is very complicated to hardwire my computer to the router. So if i can update the firmware like this, it would be perfect for me. Thanks
- Chuck_MMar 17, 2019Mentor
You should be fine updating wirelessly... as I said above, wired is preferred but either is ok.
