Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
ErnestTheGreat
Mar 04, 2019NETGEAR Employee Retired
porlockweir Its interesting that you are seeing these issue when Netgear Armor is enabled. I have been running Armor on my Orbi for past month or so on both beta and official 2.3.0.X FWs and have not observed these issues. If its not too much hassle can you back up your configuration and reset Orbi to factory settings and see if issue occurs? If the problem does not occur in default factory settings with Armor enabled load the backup config file and see if issue can be reproduced. If you can consistently reproduce the issue I would recommend to reach out to Netgear to have them investigate.
porlockweir
Mar 17, 2019Guide
Thanks for the advice - I'd had to do this with my prevuous Nighthawk but it's a real pain having to set eveyting up from scratch as the backup never seems to include every setting. I finally got it to work last weekend after 3 factory defaults, including one due to it randomly deciding to block allowed devices on access control. Perhaps Netgear needs to look at other technology manufacturers to see how a firmware update should work, as my experience with this one was very poor with hours wasted due to the bugs they didn’t spot. I now have had Armor running for a week and it seems pretty good especially with he unlimited device subscription to Bitdefender – only issue so far is that it has declared my ReadyNAS that has just been updated to the latest firmware (a much better experience than the Orbi!) as being insecure even though it should be locked down - but irritatingly just displays a blank box when I click on it to find out what this issue is.
- FURRYe38Mar 18, 2019Guru - Experienced User
Yes factory resets seem to be needed after doing autoupdates. I know it's a pain to setup.
However I recommend after doing a factory reset and set up from scratch, do a new BACKUP configuration to file so that you have a new back up file to use with the new FW update. In some cases, the older backup configs may or may not work so to avoid any issues, it's best to save off a new after a FW update and configuration has been completed.
- spasMar 19, 2019Guide
Updated from 2.2.1.210 to 2.3.0.32 and now have issues. I purchased the RBK53 Costco pack (1-RBR50/2-RBS50s) a couple years back and have NOT have any issues with ANY firmware versions till now. I separated the 2.4 and 5ghz SSIDs as per instructions from another thread since the beginning.
I went through the manual firmware upgrade procedure from V1.210 and installed V0.32 (thru 2.2.1.212) without issue (satellites first, then base unit). The RBR50 is in Router Mode.
1: Traffic Meter no longer is complying statistics.
2: The IOS App incorrectly shows the network map. I’m configured as a STAR, but the app bounces between STAR and Daisy-Chain topology.
3: The WEB GUI | ATTACHED DEVICES | CONNECTED SATELLITES | Bounces between “GOOD” and “Conifg Sync” status all the time.
4: Internet connectivity drops multiple times a day. Never happened with previous firmware versions.
5: After rebooting the Orbis. It usually 2-3 days for all the IP devices (24) to “settle –in” as I call it, where wireless devices attach to either Router or Satellite based on distance/proximity. This has been disrupted with V0.32. It was stable before but no longer. Some IP devices jump from one Orbi to another like never before.Anyone else experiencing anything similar?
- FURRYe38Mar 19, 2019Guru - Experienced User
We haven't seen or heard of others with these issues.
Possible separation of SSIDs is causing problems. It's not supported officially.
I would do a factory reset ON the entire system and setup from scratch. Walk thru the setup wizard and get it all going again. I recommend this time, do not separate the SSIDs. Leave single SSID and let it run for a bit. Factory reset has been known to clear up problems seen after a auto/FW update.
Satelites wired or wireless connected to the base ?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What is the Mfr and model# of the ISP modem the NG router is connected too?
Disable Daisy Chain temporarily after setting up from scratch and check status and behavior.
