Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
1midniterider
Mar 20, 2019Guide
Hello All,
Since upgrading from v2.2.1.210 (via v2.2.1.212), my satellites ( one RBS50 and two RBW30) frequently perform a "config sync". I've performed a factory reset on all devices and it continues to "config sync". Any other ideas?
orbilov
Mar 20, 2019Apprentice
Assuming you did upgrade to 2.3.02 after 2.12 pit stop?
- orbilovMar 20, 2019ApprenticeSorry meant 2.30.32 but for your rbw30 it looks like 2.3.04
https://kb.netgear.com/000060601/RBW30-Firmware-Version-2-3-0-4- 1midniteriderMar 20, 2019Guide
Yes, all are on the latest firmware.
Also, the RBR50 is in AP mode. The WAN port is connected to Verizon FIOS router.
