Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
spas
Mar 20, 2019Guide
I did not just do the Router. I reverted back to .210 on everything. I like keeping versions the same (if possible) on all devices. A lesson learned from 25 years + experience as a network engineer/architect.
For those who continually push for "Factory Reset". Please quantify your reasoning! I've be using Orbi for years without issue and with separate SSIDs and really do not want to spend the time to start from scratch unless it is absolutely necessary... The step I took morning restored my network infrastructure.
Zephyr3200
Mar 20, 2019Aspirant
Thanks guys for your help to install the new firmware v32.
However, I did a mistake with the satellite. I thought I had the v212 but It was the v210 prior to install the v32 but Netgear allowed me to download directly v32 without installing the v212. But i did the update correctly with my router.
Do you think It will cause me further troubles or do I let it as is ?
Thanks again.
Thanks again.
- FURRYe38Mar 20, 2019Guru - Experienced User
You can directly update to v32 on the RBS. Since the RBS size is much smaller there wasn't a need for v212. You can if you like, however others have directly updated from v210 to v32 with out problems.
Use it as is and if you notice something please post about it here.
Thanks again.
