Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
DougB628
Mar 20, 2019Apprentice
I upgraded this past weekend. So far things seem stable. I have not confirmed any fixes for problems I was experiencing - I have to get a few reboots under my belt to see if the sporadic DHCP problem is solved.
I still see devices on the attached devices page showing as connected to non-existent satellites. My satellites are named Orbi-Sat-1 and Orbi-Sat-2, and while I see devices listed as connected to both of these and my router, I also see devices that show as connected to "Orbi Satellite". It appears to be related to a page refresh issue - once the page is done refreshing, these typically update to one of my satellites. The page appears to have an automatic refresh feature, and the refresh also often takes longer than it should. So the page seems a little unstable in how it refreshes. I think it would make more sense for the connected Orbi column to be empty until it can be populated with the real value.
