Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
JohnDire
Mar 22, 2019Aspirant
How much it cost?
BrendonSF
Mar 22, 2019Guide
Interestingly, I was auto upgraded to 2.3.1.44 overnight. Not seeing it officially posted on the website as of yet, but there's a new thread on it with release notes:
https://community.netgear.com/t5/Orbi/New-Orbi-RBR50-RBS50-Firmware-Version-2-3-1-44/m-p/1725013
- FURRYe38Mar 22, 2019Guru - Experienced User
Interesting. Thanks for letting us know. Hopefully v44 is even better. :smileywink:
- DougB628Mar 22, 2019ApprenticeSo my Orbi router factory reset itself again last night. I wasn’t anywhere near it this time. This time I had backed up the configuration, so I was back in business in just 10-15 minutes. Since this happened after the firmware upgrade I’m a little more suspicious of the router now, although it could still be an unknown firmware bug.
- Zephyr3200Mar 23, 2019AspirantOn weblogin , i have “service inaccessible “ and an error message with the app when i am trying to verify firmware update.
Any idea how to solve it ? I updated to v32.
Thanks
- spasMar 28, 2019Guide
I found 2.3.1.44 for download this morning. I manually updated 2 - RBS50s (through .212) and then updated the RBR50 (through .212). I report the following:
1) WEB UI Backhaul Status no longer (at least for now) cycles through "config sync" and is steady "good".
2) Devices connect much quicker to the closest Satellite than before
3) Traffic Meter still not reporting statistics
3) The IOS Orbi App is worse. It shows "daisy chain" when I'm clearly in "star mode" as well as shows devices connected to a my Guest Network which is disabled.
When I reverted back to .210 after trying .33, everthing worked as expected, including the IOS Or.bi app
I've been a loyal NG customer for many, many years and now extremely frustrated with consistently buggy minor firmware releases..It shouldn't be like this...
- FURRYe38Mar 28, 2019Guru - Experienced User
You might try a full factory reset on the system and setup from scratch.
The Traffic Meter not working is known.
Make sure the Orbi app is up to date. Might remove the app and re-install to see if it changed the reporting behavior.
