Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
spas
Mar 28, 2019Guide
I found 2.3.1.44 for download this morning. I manually updated 2 - RBS50s (through .212) and then updated the RBR50 (through .212). I report the following:
1) WEB UI Backhaul Status no longer (at least for now) cycles through "config sync" and is steady "good".
2) Devices connect much quicker to the closest Satellite than before
3) Traffic Meter still not reporting statistics
3) The IOS Orbi App is worse. It shows "daisy chain" when I'm clearly in "star mode" as well as shows devices connected to a my Guest Network which is disabled.
When I reverted back to .210 after trying .33, everthing worked as expected, including the IOS Or.bi app
I've been a loyal NG customer for many, many years and now extremely frustrated with consistently buggy minor firmware releases..It shouldn't be like this...
Mar 28, 2019Guru - Experienced User
You might try a full factory reset on the system and setup from scratch.
The Traffic Meter not working is known.
Make sure the Orbi app is up to date. Might remove the app and re-install to see if it changed the reporting behavior.
- spasMar 28, 2019Guide
Thanks Furry. Whatever success I had vanished within minutes after posting. The "config sync" cycle reappeared, devices attached to a non-existent "guest network", and multiple device are off line. I reverted back to .210 on the RBR and RBS units and everything is back to normal and working fine..
Furry, reseting back to factory defaults is not in my plan and will not be. I believe your theory is sound but shouldn't be needed for MINOR software revisions of any knid, I could see it for a major (1st digit revisions), but not for 3rd and/or 4th digit revisions.
I'll keep .210 until I find a suitable replacement.
Anyone here have any thoughts they wish to share regarding Amplifi HD, Unifi or Synology?
- FURRYe38Mar 28, 2019Guru - Experienced User
Do you have separated SSIDs or default single SSID? One other posted about this and there not using single SSID which seems to be one cause of the config sync issue.
A factory reset would be needed in this case and to validate the FW is working correctly. Applying over older FW may have traces of older code which should be cleared out with a reset and setup from scratch. Applying FW over older version doesn't seem to be working for NG and Orbi. Some do work and some don't. Reason for those that don't to at least try a reset and setup from scratch using default settings.
- 1midniteriderMar 28, 2019GuideAre you saying that separate SSIDs are no longer supported with the 2.3.x.xx firmware releases? Is this a feature or a bug?
