Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
1midniterider
Mar 29, 2019Guide
I have a very old Linksys that cost way less than the NG Orbi and is rock solid. Now it does have a custom WRT firmware... So my expectations is the Orbi should be just as rock solid. I am not asking NG to do anything other provide is with a rock solid solution to Home WiFi... Nothing more and nothing less. I am hoping my frustration does not get the better of so I don't turn all 5 of my Orbi devices into boat anchors.
gr8sho
Mar 30, 2019Virtuoso
Given the amount of effort I'm having to expend on a much simpler configuration, it would make sense for Netgear to allow Orbi customers the option of controlling firmware updates. This would be a step towards improving stability IMHO and allow the user to schedule the update and restore the network. The issue with firmware updates breaking things is not unique to Netgear, but I do know it takes time to get things working again in a satisfactory manner. I also know this issue isn't true for everyone, but my setup is very vanilla with almost all settings in default, and yet I find it necessary to factory reset after every firmware update I get. I'd just rather do it when I can rather than get stuck in an emergency having to scramble to get things back working because of something that happened overnight while I was sleeping.
Cheers
- Ragar99Mar 30, 2019Luminary
If Netgear sent quality updates that didn't require a reset this would be a moot point. Their poor quality is the core issue.
- gr8shoMar 30, 2019Virtuoso
If it were just Netgear having the problem I'd be more willing to indict them, but there must be something intrinsically problematic with firmware updates to routers in general that I feel compelled to factory reset . I do this reset to my Arris router as well .
I don't even trust the settings backup function and choose to reenter the settings myself.
But yeah, it would be nice if in the future these updates were transparent and non disruptive.
- DougB628Mar 30, 2019ApprenticeI totally agree! It is well understood that factory resets and reconfiguration from scratch is often needed after a firmware update. Why would anyone think that automatically updating the firmware would be a good idea??
Thank you Netgear for creating the emergency situation with my wife and kids being very upset that our internet / WiFi is not working right.
If you want to automatically update the firmware, you have to solve the “saved configuration may not be compatible with new firmware” problem.
