Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
gr8sho
Mar 30, 2019Virtuoso
Given the amount of effort I'm having to expend on a much simpler configuration, it would make sense for Netgear to allow Orbi customers the option of controlling firmware updates. This would be a step towards improving stability IMHO and allow the user to schedule the update and restore the network. The issue with firmware updates breaking things is not unique to Netgear, but I do know it takes time to get things working again in a satisfactory manner. I also know this issue isn't true for everyone, but my setup is very vanilla with almost all settings in default, and yet I find it necessary to factory reset after every firmware update I get. I'd just rather do it when I can rather than get stuck in an emergency having to scramble to get things back working because of something that happened overnight while I was sleeping.
Cheers
DougB628
Mar 30, 2019Apprentice
I totally agree! It is well understood that factory resets and reconfiguration from scratch is often needed after a firmware update. Why would anyone think that automatically updating the firmware would be a good idea??
Thank you Netgear for creating the emergency situation with my wife and kids being very upset that our internet / WiFi is not working right.
If you want to automatically update the firmware, you have to solve the “saved configuration may not be compatible with new firmware” problem.
