Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
dklimas
Mar 30, 2019Apprentice
I updated the router and all three satellites to .44 after the web UI seemed to reset on it's own and most my settings were set back to defualt. Still haven't reassigned all 40 static IP's but no weird issues so far. Daisy chain is checked and the satellites are cleary in star configuration in the app though.
Everything seems to be working as expected for the past week. Coverage and speed is really good. No error messages on my mobile about WiFi calling.
I got around the lack of device usage tracking by purchasing a Firewalla Blue firewall. It allows me to see what each device is doing at any given time. Very happy with it.
Mar 30, 2019Guru - Experienced User
After setting up the router again, do a backup of the configuration for safe keeping.
Thanks for letting us know your experinece.
- DugiteMar 30, 2019Guide
Hey all, although the option for what model I have is Router Only, it is with Satelite. I have one. I am currently living in Australia and I am using Bitdefender Total Security on my system. I note that we now have support for Armor, however, there is a not on the firmware that people from Australia should "hold off for a while". Is this still the case and what is it about Australia that seems to be the issue. I have checked my firmware update on the admin page and I'm told I have the current firmware which is V2.2.1.210
option Should I be playing with this or just wait. How long before an official firmware will be released that will include Australia? This system is fantastic BTW and is the only successful one I've managed to get to work. I used the Netgear Extender which totally sucked prior. This system is fantastic. If I could get the Armor working I'd be even happier.
Cheers
- DugiteMar 31, 2019Guide
Disregard my last post, I've since found .44 and I have uploaded both firmwares to my system. So far so good. I have a Total Security 2019 subscription so lets see what happens when the trial runs out.
- FURRYe38Mar 31, 2019Guru - Experienced User
Thanks for letting us know. Enjoy.
Post about your continued experiences on v44 here:
