Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
v212 needs to be applied to the RBR, then you can apply v32:
FW 2.21.212 you can download it from here https://www.dropbox.com/s/34qdnx73uikusf7/RBR50-V2.2.1.212.zip?dl=0
alstsmith wrote:
Satellite manually updated fine, but the router update doesn't work. I get the message
"Firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I'm defintiely trying to upload the RBR firmware not the RBS one.
martinhj
Apr 01, 2019Luminary
I cannot activate Armor with this firmware....I just get invalid input. Have even factory reset it with no joy
