Feb 25, 2019Guru - Experienced User
New - NetGear Orbi Firmware Version 2.3.0.32 now available...
FW 2.3.0.32 is now available on our support site :
https://www.netgear.com/support/product/RBK50.aspx#download
RBR/RBS 50 Series Only.
To manually update the firmware, there is a need to ...
spas
Apr 07, 2019Guide
Fairwell fellow Orbi users. I sold my Orbi RBK53 system on Craigslist and moving on. Thanks to all who have been so helpful. Cheers and good luck!
1midniterider
Apr 08, 2019Guide
What did you decide to go with instead of NG?
- spasApr 08, 2019Guide
I ended up choosing the Amplifi HD Kit. So far it’s rock solid. It’s not as fast as Orbi but the performance is good and very consistent across the whole meshed network. I’m very happy the way it’s performing so far.
If my house was wired for Ethernet, I would have most likely gone with Ubiquiti Unify. The AP’s use PoE.
Cheers! - Ragar99Apr 09, 2019Luminary
Ubiquiti is 10x better than Orbi, simply no comparison. The only reason to buy Orbi is to avoid pulling ethernet which can be a big deal.
