Sep 17, 2020Guru - Experienced User
New - RBR50 / RBS50 Firmware Version 2.7.0.70 Officially Released
New Features and Enhancements: Supports Smart Parental Control Supports forcing HTTPS for the web GUI management Bug Fixes: Fixes the issue where Option 61 could not use the “@” character in t...
Mstrbig
Sep 17, 2020Master
Interesting, it still does not show up here:
https://www.netgear.com/support/download/
I guess they haven't updated the site yet.
I have been running 2.7.0.70 since this past weekend, on 2 separate RBK50 systems. I've added up to 25 devices on both systems.
It is very stable and seems to give me faster network speeds. (examble, my S10+'s network speed was always around 585. Now it is constantly 700+. The WEB GUI and app and displaying everything correctly.
It shows for me while using rbk50...
- CrimpOnSep 17, 2020Guru - Experienced User
FURRYe38 wrote:It shows for me while using rbk50...
It does not appear on "Firmware Update" on my RBR50 running 2.5.1.16. Perhaps this is related to whether a person has "gone past" 2.5.1.16 at any point?
Setting my timer today to consider updating Nov 1.
- MstrbigSep 17, 2020Master
The 2.7.0.70 mystery continues:smileywink::smileylol:
It's rock solid here.
I just performed the textbook Netgear instructions for manual firmware update.
Satellites first, then router, then reboot. Only issue was I had to go to a few devices and forget the WIFI network and rejoin. In the app there were offline devices that were also showing online as well with a different MAC address. I deleted all the duplicate offline devices. The GUI never really had any issues.
- FURRYe38Sep 17, 2020Guru - Experienced User
Possible your unit may not be reg'd with the NG servers correctly or NG isn't trigging it on everyones unit yet.
I was asked to post this:
Just got off the phone with my NG rep. He said the ONLY official releases are located here:
He said any other pushed releases may be a result of settings on the Orbi device, such as Armor, Disney, etc., and specific for that particular device, but not official for all devices.
He said he is aware of the download pages for newer firmware, but didn't comment further.
So the Netgear firmware version confusion continues.
- lukpacSep 23, 2020Apprentice
I manually upgraded to 2.7.0.70 this afternoon from 2.5.1.32. So far I haven't seen any issues.
However, I have also had problems with it not auto updating or even detecting that a new firmware is available. I know I had the same problem when I wanted to update to 2.5.1.32 back in July, and I think the problem existed last year as well. Has anyone been able to explain this? People were reporting the issue last December:
Also, is the UI very slow for everyone? Internet speeds are fine, but the UI is slow as molasses. Even the main page takes several seconds to load.
- MstrbigSep 24, 2020Master
lukpac wrote:However, I have also had problems with it not auto updating or even detecting that a new firmware is available. I know I had the same problem when I wanted to update to 2.5.1.32 back in July, and I think the problem existed last year as well. Has anyone been able to explain this? People were reporting the issue last December:
My RBR50 router never suggested an update. I manually updated mine as well. This is because some router settings like no Armor or Circle activated, etc, don't need to be updataed. So Netgear doesn't push the firmware to the routers, until the releases are reported on their website. Even then it may take a while for the router to receive an update. Some routers will get a notification and some won't. A couple RBR50 routers I've setup did get the notification and others did not. Now we are manually updating all of them.
Regarding slowness, I never experienced slowness, but did experience eroneous information for a day or 2 in both the GUI and app.
