Apr 23, 2022Guru - Experienced User
New - RBR/RBS 20/30 and 40 series Firmware Version 2.7.4.24 Released
New Features and Enhancements:
- Admin password brute force attack prevention
- Admin password strength enforcement
- EU data Analytic Opt-out
Bug Fixes:
The backup config file is an incorrect file after user sets up some configuration
Security Fixes:
- Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link :
20 Series: https://kb.netgear.com/000064872/RBR20-RBS20-Firmware-Version-2-7-4-24
30/40 Series: https://kb.netgear.com/000064873/RBR40-RBS40-Firmware-Version-2-7-4-24
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual.
To find your user manual, visit https://www.netgear.com/support/
Then enter your model number in the search box, and click the Documentation button on the product page.
If you manually update, be sure to update the RBS first, then RBR lastly.
NOTE: Update the RBS first, then the RBR lastly. After the FW files are loaded and the RBS and RBR are ready, power OFF the RBS and RBR for 2 minutes then back ON.
Unplug the power adapters from the power wall outlet.
A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
This article applies to:
Let us know how it works for you
- numzie77GuideI have an RBR40 with an RBS40. In the admin it says: V2.7.3.22 No new firmware version available.
 I find that quite strange 4 months after the new firmware was available?- CrimpOnGuru - Experienced UserYou are not alone. Netgear's process for firmware updates is a mystery to many of us. In my view, there appears to be a tangled process involving device serial numbers, physical location (US, international, EU, etc.) and time. There are several posts every week describing this exact situation. In my own case, I decided to "wait it out" when V2.7.4.24 became available. As I recall, I eventually started getting notices that it was available. Then, at least six weeks later, one morning my RBR50 had automatically updated to the new version without my doing anything. About that time there was the horrible debacle when Netgear forced an automatic update on the 750/850 series products and locked users out of administrating them. From what I hear, the automatic update process was put on hold. (Maybe the notification process was affected as well?) My position remains the same. "If it ain't broke, why fix it?" If the WiFi system is performing as expected and there appear to be no problems, there is no great urgency in updating firmware. When a new firmware release has been out for 5-6 weeks and there are not many complaints on the forum, I consider updating. The situation is entirely different if there are performance issues. - gr8shoVirtuosoDropped in to say I’ve seen emails from Netgear too as notice a new firmware update is recommended citing security fixes. In general I’m okay with this, but I’ve seen reported issues picked up by the CM with no additional follow up. So I’m sitting on the decision to apply the update and may never do it manually at this point unless more confidence is provided in this forum.
- mikosh6AspirantUnfortunately not working at all well with my RBR20 and RBS20. Ever since I installed the update my Orbi periodically disconnects from the internet and doesn't recover. It would occasionally drop the internet with the old firmware but would always recover within a minute or two. I need my Orbi working reliably. Can I downgrade the firmware to the previous version? Where would I find that version? Thanks, Mike - mikosh6AspirantDowngraded to the previous version and everything is working fine again.
- EnddaAspirantsame thing happens with my rbs20. going to look into downgrading the firmware if me re-installing this current firmware doesn't fix anything did you downgrade both the rbr20 and rbs20 to the previous firmware version, or just the rbs20 (satellite)
