MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
Rustproofcorn
Jan 04, 2017Luminary
I see. In my head I feel like I should have 3 but I have perfect coverage through my home. Can't rap my mind around it. I been fighting junk wifi sooooo long. And from what I read a 3rd unit wouldn't create a mesh it would do nothing for me. So....
- bsholbrookJan 04, 2017Apprentice
after the .34 update, any attempts to connect to the routers log page are resulting in certificate issues. Mac OSX 10.12.3, safari is complaining of an invalid root certificate with any attemps to connect to the router. and any login attempts from ios device result in cannot verify server identity. While I can override the informational message, I really dont like overriding or ignoring security elements like this. Sounds like certificates that were employed are faulty?
- Mikey94025Jan 04, 2017Hero
I never used https before with the router admin page and always used http://orbilogin.com/adv_index.htm, which is fine. It's https://orbilogin.com/adv_index.htm which isn't returning the correct security certificate and therefore your browser is warning you. Did https work correctly before with earlier firmware versions?
- ElyJan 04, 2017Luminary
Running fine for about 3 hours now, the web interface seems to be slightly faster to load now for me, I did have to reboot my cable modem and Orbi once the Firmware update was finished because it complained of no internet connection being available, a simple Orbi reboot didn't fix it, I had to reboot both cable modem and Orbi router and also the satellite.
