MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
dekka007
Jan 05, 2017Apprentice
spoke to soon. Apple TV's and logitech harmony hib just dropped....
24hours without drop then starts again.....
- Mikey94025Jan 05, 2017Hero
How are you noticing that your Harmony hub is dropping? Do you just see the light turn red or happen to press a remote button at the time? I have 2 of them but maybe I'm just not noticing it... My Nest cameras email me when they disconnect so that's why I notice their issues (when beamforming is not disabled).
- gfreyJan 05, 2017Apprentice
Nest cameras dropped connection soon as I enabled Beamforming on this latest firmware. I had to disable it again. The firmware seems more stable but still hasn't resolved the issue with Nest Cams.
- tkpittJan 05, 2017Aspirant
I have a nest camera and have beamforming turned on and it never loses connection unless I unplug the camera.
Not sure why you would be having issues but beamforming is most definitely enabled on my orbi and not causing me issues at all with my nest.
