MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
fstockel
Jan 05, 2017Star
I tried to change to the TP-cable that came with the box and this might have solved it for me (well no connection drop in approx 3hrs so far). Funny thing is that my previous cable was a hq/expensive cable (had zero issues using it with my previous Asus router). Fingers crossed.
