MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
dekka007
Jan 05, 2017Apprentice
Yes the dropouts seem to be directly related to these two performance enhancing options.
- bsholbrookJan 05, 2017Apprentice
I agree with that summary, I have had no connectivity issues since .16 as long as mimo and beam form are off. However, theses are features that a high end product should support and which should work. Hopefully the netgear team will see these threads and take the needed steps.
