MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
dekka007
Jan 05, 2017Apprentice
Yes the dropouts seem to be directly related to these two performance enhancing options.
bsholbrook
I agree with that summary, I have had no connectivity issues since .16 as long as mimo and beam form are off. However, theses are features that a high end product should support and which should work. Hopefully the netgear team will see these threads and take the needed steps.
