MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
Rustproofcorn
Jan 05, 2017Luminary
No kidding read the article. Implicit didn't work well. Beamfoaming already is enabled. Why turn in implicit? For it to work both hardware have to mesh which they may not. Only explicit is a standard the other is hit and miss. Good catch Irish. Gonna turn on mimo now.
Jako888
Jan 07, 2017Star
There seem to be two threats on the same topic. So post in both to make sure moderator picks it up and speak to the techies.
Installed .34 yesterday.
Still having iOS drop outs. Netgear really need to get this sorted. How hard can it be to test to make sure it works instead of releasing another firmware and cross fingers?
- MarkC1024Jan 07, 2017Luminary
We have an iOS household and no issues, so it might be difficult to reproduce and test. Problem reproduction is a critical phase in fixing a problem. Have you tried to do a network reset on your iOS device to see if that helps?
