MarkC1024
Jan 03, 2017Luminary
New Firmware 1.4.0.34
Just downloaded and installed manually; doesn't yet show under Online Update. The only note is minor bug fixes, but would be good to get a better read on what is fixed. It does seem that the previo...
Jako888
Jan 07, 2017Star
There seem to be two threats on the same topic. So post in both to make sure moderator picks it up and speak to the techies.
Installed .34 yesterday.
Still having iOS drop outs. Netgear really need to get this sorted. How hard can it be to test to make sure it works instead of releasing another firmware and cross fingers?
MarkC1024
Jan 07, 2017Luminary
We have an iOS household and no issues, so it might be difficult to reproduce and test. Problem reproduction is a critical phase in fixing a problem. Have you tried to do a network reset on your iOS device to see if that helps?
