MuhammadAsif's avatar
MuhammadAsif
New Firmware RBR40
Hello,
      Recently i update my Orbi FirmWare & facing issue connected devices are not showing even andriod device also missing. I install manaully also but the same problem.
Any solution kindly help?
1 Reply
  • FURRYe38's avatar
    Please try a factory reset and setup from scratch with the RBR and RBS.
    Power OFF the ISP Modem for 30 seconds then back on. Walk thru the setup wizard on the RBR with a wired PC.
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Setting
    Uninstall the Orbi app from your devices then re-install and log back in.
