Celeri
Oct 12, 2018Star
New framework and wifi calling
Hello,
Since new framework, and with Circle enabled, wifi calling stopped working.
When i disable Cicle, everithing works well.
Do you have this problem (i live in France, with SFR as p...
Oct 12, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Has a factory reset been performed and set up from scratch after the FW update?
Celeri
Oct 28, 2018Star
Nothing worked ! Still no access to WiFi calls...
- Blanca_OOct 28, 2018NETGEAR Employee Retired
Hi Celeri
May I please know the following information:
- Carrier for Wi-Fi calling?
- Was it working before?
- Will it work if filtering level is set to NONE?
- Device/Phone affected?
We look forward to your response.
Blanca
Community Team- CeleriOct 28, 2018Star
i live in France, with SFR as provider
Off course it was
YES
3 iPhone
