netgearguy
Dec 19, 2017Apprentice
New FW V2.1.1.16 (Router) and V2.1.0.18 (Beacon) - what's your experience?
Just received replacement RBK30 (RBR40/RBW30) Orbi system from Amazon and udpated to the current FW: Router RBR40 RBR40 V2.1.1.16 Satellite RBW30 Orbi Satellite-1 V2.1.0.18 ...
aaz
Dec 19, 2017Virtuoso
I am running the RBK50 with two satellites all on 2.1.1.16 for the last few hours and all the issues that I reported are gone. This one is stable, at least it seems for this hardware.
Op I notice you are running different versions of hardware, including one that does not have newer firmware so that may be contributing to your instability.
- JMU1998Dec 19, 2017Luminary
My Orbi is in AP mode, It has been about 5 hrs and issue returned, I even did a factory reset on both after the firmware update all devices show attached to main.
- aazDec 19, 2017Virtuoso
As I mentioned before - re-deploy the firmware to both satellites and router - that seems to have helped some people here with instability before. I'd also say after updating export your settings and then re-import them. Give time to stabilize and then power off router and satellites for 2 minutes before restarting.
What you are experiencing has to be a config issue.
- netgearguyDec 20, 2017Apprentice
I've been on the phone wNetgear level 2 support (my case escalated, they called me) and we went through an hour or more of TS and nothing changed, network drops continued.
Given this is my second set of HW and I have exactly the same results on both HW sets on multiple versions of 2.0.x and 2.1.x FW versions, after factory resets and re-flashing, I think it's clear there is a serious issue w/Orbi FW (and possibly some of their HW components) that is causing these issues.
aaz wrote:I am running the RBK50 with two satellites all on 2.1.1.16 for the last few hours and all the issues that I reported are gone. This one is stable, at least it seems for this hardware.
I'm running an Orbi system sold by Netgear - RBK30, which includes one router (RBR40) and one Satellite (RBW30). They are a matched set and sold together by Netgear, and both were updated to the current FW available via the FW update process (auto, not manual) from the router.
