netgearguy
Dec 19, 2017Apprentice
New FW V2.1.1.16 (Router) and V2.1.0.18 (Beacon) - what's your experience?
Just received replacement RBK30 (RBR40/RBW30) Orbi system from Amazon and udpated to the current FW: Router RBR40 RBR40 V2.1.1.16 Satellite RBW30 Orbi Satellite-1 V2.1.0.18 ...
JMU1998
Dec 19, 2017Luminary
My Orbi is in AP mode, It has been about 5 hrs and issue returned, I even did a factory reset on both after the firmware update all devices show attached to main.
aaz
Dec 19, 2017Virtuoso
As I mentioned before - re-deploy the firmware to both satellites and router - that seems to have helped some people here with instability before. I'd also say after updating export your settings and then re-import them. Give time to stabilize and then power off router and satellites for 2 minutes before restarting.
What you are experiencing has to be a config issue.
- netgearguyDec 20, 2017Apprentice
I've been on the phone wNetgear level 2 support (my case escalated, they called me) and we went through an hour or more of TS and nothing changed, network drops continued.
Given this is my second set of HW and I have exactly the same results on both HW sets on multiple versions of 2.0.x and 2.1.x FW versions, after factory resets and re-flashing, I think it's clear there is a serious issue w/Orbi FW (and possibly some of their HW components) that is causing these issues.
