Sweetmo
Jun 03, 2026Tutor
New ISP - now RBR40 loses internet constantly
Community, I need your input. I had to switch to a new ISP recently due to a change to my prior ISP that was giving me poor Mbps on 5G due to tower locations. I had no issues for the past 8 year...
- Jun 07, 2026
Thanks everyone that submitted input. After several hours of working through reboots , changing settings, and updating firmware, I took the advice of some of you and reached out to Charter/Spectrum. They agreed to come out again same day. Turns out the initial setup was done by a contractor and was not a technician. The contract had a poor connection and left old fittings and reused an existing cable inside the home that was not adequate for the service. Frustrating when they say it's installed correctly, and it's not.
CrimpOn
Jun 03, 2026Guru - Experienced User
Sweetmo wrote:I figured no problem and easy install for the tech.
A tech came out from Spectrum, checked the cable signal, and installed the modem?
I also have Spectrum cable. My RBR50 fully supports IPv6 on Spectrum.
