Guytech's avatar
Guytech
Apprentice
Apr 25, 2017
New Netgear Genie app drains iPhone battery quickly
Has anyone else noticed a significant batery power drainage with the new Genie app? I noticed it while playing around in network map. One can actually see how the percentage drops down. Maybe someone can give the tech guys a heads-up on this?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Guytech
    Are you saying you are seeing the drainage when using it or with it running in the background or both?
    DarrenM
    • Guytech's avatar
      Guytech
      Apprentice
      Hi Darren
      I noticed it when connected to my local network and seems only when browsing around in the network map section. I did not notice the same issue when connected remotely with the same app. Running in the backround did not cause any significant battery drainage.
      Thanks
      • DarrenM's avatar
        DarrenM
        Thanks for the info I will look into it and report the issue.
        DarrenM
  • Yes, this is definitely still a problem. I hope it will get fixed soon...
