jmschnur923's avatar
jmschnur923
Luminary
Dec 06, 2017
New Orbi 2.1 firmware
Who here have downloaded the new 2.1 firmware and find it works well?
    It's working great for me - installed ~24 hours ago, and I have no operability issues so far.
    I wasn't having any issues with last few f/w versions either though.
  • Firmware v2.1 manually installed and no problems whatsoever.  But then I have not had any problems in over 6 months of ownership.
    • JMU1998's avatar
      JMU1998
      Luminary
      Can anyone please list the correct steps to upgrade Firmware for those who are little more tech inclined.  including how to clean out nvram etc...
    • st_shaw's avatar
      st_shaw
      Master
      Installed v2.1 yesterday with no issues noted so far.  No special procedures, no NVRAM clearing, etc.  Just a manual install via admin GUI, updating the satellite first. The only issues I've had since installing Orbi in January '17 have been due to misconfiguration of other devices on the network--Sonos on the same channel, running other WiFi routers, placing other wireless devices too close to Orbi, etc.
      • JMU1998's avatar
        JMU1998
        Luminary
        st_shaw I would like to use the nvram clear method, I used the speedtest built in Orbi and I suspect some of my buffering issues are because of that.  I want to start as clean as possible with this Firmware version on the Orbi.  if you could send me instructions of best practice including nvram clear step that would be fantastic. I know how to enable telnet.
      • jmschnur923's avatar
        jmschnur923
        Luminary
        Satellites do not show attached devices although they show up in router.
    I have installed v2.1.1.12 without any problems at all coming from v2.0.0.74 - never had any problems with my Orbi for the past 8 months except for the S8 bug that was resolved after an Android update a month later..
    I feel that the newest v2.1 has an even farther range at my home into my yard after the latest update.
  • After the update, as before, I still have to power cycle my satellite several times per day, sometimes every 1-2 hours as it still drops internet connection.
    • sleepr88's avatar
      sleepr88
      Apprentice
      I just want my money back (out of return window)... I will never buy, or recommend any Netgear product again... they have taken way too long to fix any of the issues with the Orbi system
      • sleepr88's avatar
        sleepr88
        Apprentice
        TP-link, Linksys, and others have already gotten it fixed... How long for a Chromecast/Android fix Netgear?
