Jul 06, 2020Guru - Experienced User
New Orbi 50 series Firmware Version 2.5.1.32 FW Release
RBR50, RBS50, RBK50, and RBK53 New Features and Enhancements: Improves the NTP sync speed and success rate Includes updates to the Terms and Conditions and adds a Privacy Policy link Bug Fix...
jijun1964
Jul 24, 2020Guide
Dea, after I update firmware to v2.5.1.31, I have issue with Orbi Web view don't display any "Attached Devices", same as on mobile device. on mobile app still show connected RBS.
Jul 25, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
Try a different browser, IE11, Edge, Firefix or Opera.
Be sure to clear all browser caches before starting the setup wizard.
IF this fails to correct the problem, please revert back to v16:
jijun1964 wrote:Dea, after I update firmware to v2.5.1.31, I have issue with Orbi Web view don't display any "Attached Devices", same as on mobile device. on mobile app still show connected RBS.
- dpdurstJul 25, 2020Luminary
See my giant post if you can find it, seems its either not posted or being reviewed, I have the same issue with wireless devices using DHCP and as well as static wireless devices. I can tell you that a default doesn't fix anything so don't bother. I just went through this all this morning and no change.
Wired devices seem perfectly fine- FURRYe38Jul 25, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.Try a different browser, IE11, Edge, Firefix or Opera.
dpdurst wrote:See my giant post if you can find it, seems its either not posted or being reviewed, I have the same issue with wireless devices using DHCP and as well as static wireless devices. I can tell you that a default doesn't fix anything so don't bother. I just went through this all this morning and no change.
Wired devices seem perfectly fine- Sioux_HockeyJul 26, 2020Tutor
I have had issues with this release. Download speeds are around 100Mbps after restarting router. Then after a minute passes download speeds go down to 50 Mbps and stay there until I restart the router and then the whole process of slowing down after a minute repeats itself. I did a factory reset on the router and satellite, and also downgraded the firmware to 2.5.1.16 and that did not help. Any other suggestions?
Thanks
