dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
webminster
Jan 21, 2018Luminary
Yes, I have the irregular ping times on local network as well. 2.1.2.18 so far has been better than 2.1.1.16 and 2.1.2.10, which actually appeared to drop pings (may have actually been just way-too-long returns).
I think others have observed similar issues on wide variances of ping response times. I've compared the tests to previous ASUS router, it definitely originates in the Orbi. Either some QoS issue or something - I have tested same when connected to the router instead of satellite, and also get the variances - just not quite as bad as when going through the satellite.
PhiloF wrote:I just bought an Orbi100 kit. I upgraded to firmware RBR50-V2.1.2.18 and RBS50-V2.1.2.18
The Wired Satellite backhaul has an irregular response. Have other users encountered the same problem? I'm the only device connected to the 5g; WiFi scan shows no other network on that frequency.
This is a sample ping from wireless client to satellite RBS50:
MACBOOKPRO-C8A8-298:~ philippeflichy$ ping 192.168.223.121
PING 192.168.223.121 (192.168.223.121): 56 data bytes
64 bytes from 192.168.223.121: icmp_seq=0 ttl=64 time=2.133 ms
64 bytes from 192.168.223.121: icmp_seq=1 ttl=64 time=2.346 ms
64 bytes from 192.168.223.121: icmp_seq=2 ttl=64 time=2.372 ms
64 bytes from 192.168.223.121: icmp_seq=3 ttl=64 time=3.092 ms
64 bytes from 192.168.223.121: icmp_seq=4 ttl=64 time=4.352 ms
64 bytes from 192.168.223.121: icmp_seq=5 ttl=64 time=2.804 ms
64 bytes from 192.168.223.121: icmp_seq=6 ttl=64 time=108.457 ms
64 bytes from 192.168.223.121: icmp_seq=7 ttl=64 time=72.484 ms
64 bytes from 192.168.223.121: icmp_seq=8 ttl=64 time=58.553 ms
64 bytes from 192.168.223.121: icmp_seq=9 ttl=64 time=1.915 ms
64 bytes from 192.168.223.121: icmp_seq=10 ttl=64 time=1.409 ms
PhiloF
Jan 21, 2018Tutor
Thanks for confirming! I have the same amount of drops when connecting to the main unit. It is so bad that I have audio drops I never encountered this with my previous Apple system... Wondering if I should send all these supposed marvels back to Amazon .... The coverage and the signal are definitely very good but what's the point if I cannot listen to my music ?)
