dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
DG808
Jan 29, 2018Initiate
After updare wired connections failed for about 30 minutes then started working. Biggest problem is with S6 THAT STILL DROPS CONNECTION constantly, if not plugged in all night end up with dead battery many mornings. Keep wifi turned off except when using WIFI for some time. Obtained Arris WiFi as secondary and now connect S6 to it and it never drops signal, only problem is very low signaly strength at far end of home which is what I purchased the ORBI for in the first place. Ipads have only lost connection once or twice they seem to stay connected to ORBI. Hoped this version would correct the dropped connections on the S6 no luck. Maybe an S6 probem though my wifes S5 also drops off ORBI just much less frequently than mine. The the S5 did drop the connection once with the new version but the S6 is unusable.
itzcoatl13
Jan 29, 2018Guide
Try resetting the dhcp range by creating a new dhcp range. For example, instead of using 192.168.1.1 - 192.168.1.254, use 192.168.0.1 - 192.168.0.254. This will force dhcp to assign a whole new ip address to every device.
I believe the modem (or router) and/or connected devices are remembering the old settings (from the older firmware) and conflicting with the upgraded orbi.
