dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
RogerSC
Feb 02, 2018Virtuoso
I believe that I've found a way to block auto-update, but it most likely isn't worth most people's time. And will create problems if you need ftp to access your home network remotely. Using dd-wrt on my "main" router (Orbi is in AP mode), when I block ftp, that prevents the Orbi from doing auto-update flashing. Not even seeing the "newer firmware available" banner on the Advanced Status page after almost 4 days.
I'd much rather see Netgear provide a method for blocking firmware auto-update when a particular firmware version doesn't play well with one's collection of home network clients. Rather than repeatedly forcing their users onto a firmware version that isn't working for them. And wasting the time of people like me that compulsively solve problems like these *smile*.
The Orbi has been very stable for me most of the last year that I've had it. V2.1.2.18 release is the first firmware version I've had a functional problem with in over a year of use. I'm currently evaluating whether it's worth it to me to spend the time to battle Netgear's firmware developers fervent desire that I stay on a firmware version that isn't working for my home network, versus giving me the tools to do make my home network functional. It would be much easier for Netgear to simply add a web admin interface switch to temporarily disable auto-update, versus all the time that I've spent in getting to the same place. Ending up having to disable part of my home network to accomplish the same goal.
sleepr88
Feb 02, 2018Apprentice
maybe Netgear will fix Orbi correctly if enough people also upvote this:
https://community.netgear.com/t5/Idea-Exchange-For-Home/I-would-like-the-Orbi-wifi-system-to-work-correctly-again/idi-p/1491327
