dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
RogerSC
Feb 05, 2018Virtuoso
Tired of fighting with the Orbi, giving the eero a try. So far, I'm very impressed. Have it in bridged mode (as an AP), and it is giving me solid, full speed wireless coverage across my house. Got the Pro gen 2 system, 3 "Pro" nodes. Have two nodes downstairs, one upstairs. Due to the low profile, you can put them just about anywhere. Setup took about 10 minutes, from "unboxing" to having a functioning mesh network, the app guides you through setup. The eero app is great, nice user interface, lots of information available. Think that I'm going to like it, I'm feeling more relaxed already *smile*. It just works, don't feel the need to monitor it all the time. No disconnects or problems since setup. Very happy at this point. It is early yet, though. Still have the Orbi, I can go back to it if I need or want to.
tsig
Feb 06, 2018Luminary
Have they addressed the issue of if you lose external internet that your internal network will go down?
- webminsterFeb 06, 2018Luminary
I thought that was specifically if your Internet connection goes down, AND your gateway Eero device gets reset. But still lousy. The one thing I didn't like - dependency on cloud for configuration...
- RogerSCFeb 06, 2018Virtuoso
wrote:I thought that was specifically if your Internet connection goes down, AND your gateway Eero device gets reset. But still lousy. The one thing I didn't like - dependency on cloud for configuration...
Don't know about what happens if the internet is down yet, but according to smallnetbuilder, the eero gen 2 continues to operate. My internet hardly ever goes down. And I have my main router, an R7800 to fallback on if I feel I need it. All I have to do is turn on the radios on it, and my local network is back. Although, at this point, I don't have much use for my home network if the internet is down. But, as I said, what I've read is that the eero gen 2 fixed that problem.
By the way, the eero continues to just work, and work well. I've got no problem with that *smile*.
- Richard1864Feb 07, 2018LuminaryThe Eero network does continue working after losing internet connectivity. The only issue I have with Eero is the complete lack of IPv6 support, which is becoming vital since IPv4 addresses have been exhusted. The backhaul between Eero’s is only a maximum of 600 mbps, vs 1.7 Gbps for Orbi, and more than 1 Gbps for other networks.
However, I have found Orbi Pro and Eero to be the most reliable mesh networks, and I’ve tried most of them all.
