dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
lbdyck
Feb 09, 2018Star
Had to reboot for an iTunes update and then spent 30 minutes trying to get my desktop running Windows 10 Home 64bit current build to connect to the internet. It would connect but not have internet while my iphone, ipad, and laptop all had internet connectivity. Had to turn off wifi and back on, disconnect, connect, and reboot twice, and then something worked and i had both network and internet connectivity. My desktop is less than 60 inches away from the Orbi router.
My laptop has this issue frequently.
Netgear - WHEN WILL THIS BE FIXED?
My wife hates the gaming routers - too darth vader ish and likes the esthetics of the orbi so i can't replace it BUT I WILL if this continues much longer. I've had it for over a month now and have been patient but that only goes so far.
At the very least Netgear should be offering rebates to all of us impacted along with their apologies for this mess.
itzcoatl13
Feb 09, 2018Guide
Hi,
When this happened to me (almost the exact scenario), I had to give the laptops a static address, then they worked just fine.
