dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
Cereal
Feb 10, 2018Tutor
wrote:
wrote:
wrote:
wrote:Ever since 2.1.2.18 my RBR50/RBS50 AP Mode setup will not go above 10-20Mbps download on any device I test from (tablets, phones, laptops). I have verified via wired connection my internet is functioning properly (120/10). The devices can be connected on 2.4 or 5Ghz, it doesnt matter just slow speeds all around
6D) Just to add, I am a network engineer... troubleshooting network issues is something I have been doing my entire career. I am human and may have missed something but this is a simple network setup and sectionalizing the issue has shown me it is orbi.
>> 6D) I would guess that you have run tracert command based upon you being a network engineer. What were the results up to where you connect to your IP host provider (next hop just outside your cable modem)? Anything stick out?
Networking is like a bowl of cherries.
You don't want to eat the stems.
Couple things:
1) traceroute (mtr actually as it looks nicer :) ) have looked clean, nothing to indicate a problem
2) given that speedtests from the Orbi itself and via wired are fine than I would not expect an issue on my router/fw with my ISP.
Again the only issue I see is with wifi devices that cannot seem to break this 20Mbps barrier no matter if its on 5Ghz or 2.4ghz and no matter the device.
Here is an iperf test result between a wired linux host in my network and a laptop on wifi (Macbook pro on 5Ghz), bit better than speedtest (slightly over 20) but still terrible:
$iperf3 -c 192.168.1.11
Connecting to host 192.168.1.11, port 5201
[ 4] local 192.168.1.103 port 50124 connected to 192.168.1.11 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 3.46 MBytes 29.0 Mbits/sec
[ 4] 1.00-2.00 sec 2.72 MBytes 22.8 Mbits/sec
[ 4] 2.00-3.00 sec 2.71 MBytes 22.7 Mbits/sec
[ 4] 3.00-4.00 sec 2.68 MBytes 22.5 Mbits/sec
[ 4] 4.00-5.00 sec 2.71 MBytes 22.8 Mbits/sec
[ 4] 5.00-6.00 sec 2.71 MBytes 22.7 Mbits/sec
[ 4] 6.00-7.00 sec 2.73 MBytes 22.9 Mbits/sec
[ 4] 7.00-8.00 sec 2.69 MBytes 22.5 Mbits/sec
[ 4] 8.00-9.00 sec 2.70 MBytes 22.7 Mbits/sec
[ 4] 9.00-10.00 sec 2.75 MBytes 23.1 Mbits/sec
[ 4] 0.00-10.00 sec 27.9 MBytes 23.4 Mbits/sec sender
[ 4] 0.00-10.00 sec 27.9 MBytes 23.4 Mbits/sec receiver
To the same iperf server again but this time wired, to show it can handle up to 1Gbps:
[ 4] local 192.168.1.222 port 50210 connected to 192.168.1.11 port 5201
[ 4] 0.00-1.00 sec 105 MBytes 880 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 940 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 940 Mbits/sec
[ 4] 3.00-4.00 sec 112 MBytes 940 Mbits/sec
[ 4] 4.00-5.00 sec 112 MBytes 941 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 940 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 941 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 940 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 940 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 940 Mbits/sec
[ 4] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver
kennyj
Feb 10, 2018Aspirant
Couple things:
Since you can't get the speed on neither WiFi 2.4 nor 5Ghz and wired is OK, I would suspect bad router. I have no other ideas at this point. Perhaps someonce else can chime it. All I can say is that it did work for me in AP mode. Hope you find solution.
- CerealFeb 10, 2018Tutor
Couple things:
Appreciate the help. I'll try the old factory reset, reboot everything, etc, etc. I would be surprised if its hardware as it was working great prior to the recent firmware update but things break sometimes.
- JMU1998Feb 10, 2018Luminary
Anyone know if a new Beta Firmware coming?
