dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
setham
Feb 13, 2018Star
Hi,
I wanted to wait a couple of weeks before posting about my upgrade to 2.1.18.
I have a Linksys WRT1200AC running OpenWRT as the router (wifi disabled) and the Orbit and 2x Satellites as AP.
- Daisy Chain Enabled
- Beamforming, MU-MIMO & Fast Roaming Disabled
As I mentioned in a prior post I have a raspberrypi (stationary, not roaming across the system) monitoring that the three Orbi devices are up and running. Monitoring among other things is pinging the 3 Orbis, checking that the 6 SSIDs are broadcasting (3x 2.4 Ghz + 3x 5Ghz), that different stationary wireless and wired devices on my LAN respond to ping, that DNS is working and that pinging 3 different internet hosts is successful.
I have had no issues for 2 weeks in a row, no reboots, no SSIDs drops, or lack of connectivity to my LAN or the Internet. WiFi speed and coverage are outstanding.
I briefly tried to enable fast roaming and the reboots and disconnection started happening again, so in order to keep peace at my home, I have not touched the configuration anymore.
Roaming does not work well, when moving around the house I find myself turning off/on my cellphone wifi so it picks the closest Orbi.
Though the Orbi system can be considered by many a configure-and-forget device, not being able to enable key features due to its instability¸ which I expected and paid to work, like fast roaming or beamforming it is disappointing.
