dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you may have.
Thanks,
Dave
- FURRYe38Guru - Experienced UserThe first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.New beta FW avaialble. Get it while its hot of the press:
I'm currently running firmware version 2.1.2.18 with ZERO issues whatsoever. Have been this entire time.
If all goes well, I'm assuming that NETGEAR will auto push this new firmware out at some point, right? Including for users running 2.1.2.18?
- RogerSCVirtuoso
Mr-Wednesdaywrote:I'm currently running firmware version 2.1.2.18 with ZERO issues whatsoever. Have been this entire time.
Yes, it will be auto-flashed on your Orbi shortly after release, I'm sure.
The beta will not be pushed. It's a manual upgrade only. When and if NG deems it fit for world wide release, then it will be pushed via auto update.
- jdewarAspirant
Hi, since the new upgrade I have experienced losing internet connection, constant drop out of the orbi Wi-fi network espically on iPad and i phone. It’s really frustrating as this network should be rock solid, I have 1 Orbi router and 3 satellite units.
- DarrenMSr. NETGEAR Moderator
Hello Jdewar
Have you tried to factory reset the unit since updating to the latest firmware also are you using 2.1.3? if not you can find that firmware in this thread below.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584
DarrenM
