RedBatman89
Oct 03, 2018Guide
New Orbi Firmware V2.2.1.210 had caused me to factory reset
So this morning my rbk23 orbi updated to V2.2.1.210 and was causing issues on me though I had power cycled since I was getting interent issues so I might have borked something. Since after the update...
totekin
Oct 25, 2018Aspirant
This firmware caused my security to be disangaded. So now any one can join my network :(
Oct 26, 2018Guru - Experienced User
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
After the FW is re-loaded, reset the the system and setup from scratch. Be sure to walk thru the setup wizard and write down important information for safe keeping. Setup new SSID names and PWs. Use WPA2 and AES settings.
