Kev77
Jun 06, 2018Tutor
New Orbi install
Newbie here guys. I upgraded from a Netgear ac1750(Connected to PACE AC5268 through AT&T) to the AC3000 system. Took awhile to get everything synced and working but once it was working, it was not ve...
Jun 11, 2018Guru - Experienced User
Try disabling MIMO, Daisy Chain and Fast Roaming.
Other channels 1 and 11 busy?
Are you sure the radios on the modem are Disabled fully? No just hide the SSID names, there should be a disable radio feature possibly on the modem as well.
- Kev77Jun 11, 2018Tutor
I will try to disable MIMO, Daisy chain etc tonight. Yes the radios are disabled fully, there is an option in the modem to disable the radios. Thanks for the input
does the Orbi "mesh" feature still work in AP Mode? Is it switching devices as they move around, etc?
