Kev77
Jun 06, 2018Tutor
New Orbi install
Newbie here guys. I upgraded from a Netgear ac1750(Connected to PACE AC5268 through AT&T) to the AC3000 system. Took awhile to get everything synced and working but once it was working, it was not ve...
Jun 11, 2018Guru - Experienced User
Try disabling MIMO, Daisy Chain and Fast Roaming.
Other channels 1 and 11 busy?
Are you sure the radios on the modem are Disabled fully? No just hide the SSID names, there should be a disable radio feature possibly on the modem as well.
Kev77
Jun 11, 2018Tutor
I will try to disable MIMO, Daisy chain etc tonight. Yes the radios are disabled fully, there is an option in the modem to disable the radios. Thanks for the input
- Kev77Jun 11, 2018Tutor
does the Orbi "mesh" feature still work in AP Mode? Is it switching devices as they move around, etc?
