BeckieStewart's avatar
Mar 27, 2019
New Orbi Installation Fail
I have a Netgear N900 Wireless dual band router that works fine within 1000 sq ft.
I want to extend my range to 3500 sq ft.
I bought the ORBI RBK23W/AC2200 unit.  I used mobile app and tried to install according to instructions on app.  But.....After I made connection to ORBI router and power supply, it just sits there.  The white light went through it's sequence and then went out.    My phone app is sitting on next and won't go pass this point.
So now I am reconnected to the N900 router and have a paperweight.  Any suggestions on connectivity to ORBI.
  • So you are keeping your original router and using Orbi as an AP?
    Or are you removing your old router and replacing with Orbi?
    Regardless of above, what is the make/model of your modem that your previous router is connected to?
    • Am relacing the Netgear N900 router with the Orbi.
      Have a new ARRIS DOCSIS 3.0 cable modem Model SB6183.
      the new modem works with the N900 router but when I switch out to ORBI router..it doesn't work.
      I have rebooted modem, desktop and ORBI various times
      • Chuck_M's avatar
        Chuck_M
        Mentor
        I think it would be best to install it using a PC and being wired to Orbi... do you have that capability?
  • FURRYe38's avatar
    DId you power OFF the 6183 modem along with the RBR for 30 seconds, then power ON the modem first and let it sync, then power ON the RBR and walk thru the setup wizard with a wire connected PC?
