iarsenal85
Jul 30, 2018Aspirant
New Orbi RBK50 - Suggested Firmware and Settings
Hey guys,
What suggestions do you have on what firmware to run to minimize any issues? Any specific settings?
Thanks!
Jul 30, 2018Guru - Experienced User
Ok just checking for a router built into the modem. Stand alone modem is preferred. If your not using any switches, thats fine. If you do, just make sure they are NON Managed switches.
You should be fine if you want to follow what I did on my friends system.
iarsenal85
Just plugged it up and rebooted my cable modem. Followed the setup through browser and let it upgrade on its own. Satellite upgraded fine on its own. Speed test 450/23 on my 400/20 Spectrum plan. So far so good on coverage throughout the house and in my yard, half acre property. Let's see if it stays stable.
