SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Mar 22, 2019Guru - Experienced User
Poeple been screaming about this for years. Doesn't sounds like its going to happen.
You can post here about it though:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
gr8sho wrote:
I do hope Netgear is reading this. I want the option to do the update myself manually on my own schedule. Things are now screwed up and I'm in the process of having to stop what I'm doing and perform a factory reset to get things back to working order.
Thank you.
gr8sho
Mar 22, 2019Virtuoso
I've learned to stop shoveling sand against the tide. Do any NG routers allow for manual management of firmware updates?
- ReallyAnnoyedAFMar 22, 2019Star
Auto, manual, don't care - just fix the wifi.
- FURRYe38Mar 22, 2019Guru - Experienced User
There R series does. Not sure about the newer RAX series.
