SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
SW_
Apr 20, 2019Prodigy
Dabbit wrote:
...The two satellites show as 'waiting for connection'...
I ran into similar issue with my setup on v44. Check it out here.
Also, if you setup two separate SSIDs, check this post and post.
Dfran1
Apr 20, 2019Apprentice
updated to .48 and now any device on the satelite is 1/4 the rated speed, I just tried a total reset of the satelite and a telnet
1. config default
2. config commit
3. reboot
same sloow speed so I will try a total factory default as soon as I can, unless someone peosts something else to try.
any device thats connects wifi to the main works great, but the satelite wifi 5G at least sucks big time
thanks
