SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
gr8sho
Apr 22, 2019Virtuoso
Hello,
Can you kindly explain please how on earth you're ablie to get the switch to enable disable auto updates?
SW_ wrote:
- FURRYe38Apr 22, 2019Guru - Experienced User
Is the disable radio button not working for you?
gr8sho wrote:
Hello,
SW_ wrote:
- gr8shoApr 22, 2019Virtuoso
I don't have it. Was it introduced in .48? This is a question I've asked before with no response. I don't want to update unless I know for a fact it comes with the new firmware as I'll have to schedule a factory reset.
Oh ok. Well seems to have been intro'd with v48 as it was posted by SW. I'll be updating the RBR I have to check this as well.
- SW_Apr 27, 2019ProdigyRe: New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Hello,
@SW_ wrote:
Hi gr8sho ,
Please check Orbi-Router Auto Firmware Update Switch.
Have fun!
- FURRYe38Apr 29, 2019Guru - Experienced User
I see, gotta enable this hidden feature. I'll try this out. :smileywink:
SW_ wrote:
Re: New Orbi RBR50/RBS50 Firmware Version 2.3.1.48Hello,
@SW_ wrote:
Hi gr8sho ,
Have fun!
