adambean
Jul 18, 2017Luminary
New Orbi setup - satellites keep disconnecting
Hey all, Just finished setting up the Orbi. Upon updating the firmware for the router (manually), I had to re-sync the satellites. Took a few tries, but ended up working. Post updating the firmwa...
adambean
Attempted another factory reset. How long should the router have a solid white light? It's been roughly 5 minutes, still solid and unable to connect.
adambean
I'm giving up. I'm unsure what to do at this point. I've factory reset ... 6+ times now to no avail. A couple times I get into the router setup and I can't get past the first couple screens. Have tried both wired and wirelessly, nothing.
Seems like others have upgraded and dowgraded firmware without issue. Perhaps mine is just totally screwed post upgrade/downgrade?
Oh so fun, well worth $500!
- captain_phaserJul 18, 2017Apprentice
adambean Unless Netgear themselves can give you a solution, I would go do a return or exchange from where you bought them. If you can't even configure the router there's nothing you can do. Also, when you were updating, I'm assuming you followed Netgear's recommended process of being on a wired connection and updating the satellite first and then the router?
